s219
Super Member
- Joined
- Dec 7, 2011
- Messages
- 8,548
- Location
- Virginia USA
- Tractor
- Kubota L3200, Deere X380, Kubota RTV-X
The 240V 20A circuit breaker down on my pier, for my boat lift, has been getting flakey when switched on during the last couple weeks, periodically failing to connect one leg. I figured corrosion or moisture. Finally on Friday, it made some sizzling noises and would not connect after 3-4 tries. So I bought a new breaker and replaced it.
Tonight I took the old breaker apart to see what the problem was. Breakers aren't really meant to serve as switches (unless using a specially designed breaker made to function as a switch), but it should take thousands of switching cycles before they wear out, and at best this breaker might have had 100 cycles since installed. So I was suspecting some premature wear or some moisture or corrosion on the contacts. Instead I found this:
That's what's left of a caterpillar that managed to get inside one side the breaker, between switch contacts, and eventually got cooked. I am at a loss to explain how a caterpillar got in the circuit panel, never mind inside an actual breaker! There are very few openings in the breaker, so I wonder if the thing got inside when small and just grew in there, getting stuck.
I plan to look over my circuit panel closely tomorrow, and plug any holes that could let insects in. It's an outdoor rated GE panel, but clearly must have some holes a caterpillar could get through.
Just when I think I have seen it all with electricity, I learn of something new and bizarre!
