Price Check L3800 price check
   / L3800 price check #11
I agree that 4WD is awesome, but if this tractor will replace a 8N, then 2WD will still be fine to pull logs and brush hog.
   / L3800 price check #12
I paid 15k for my L3800DT 4wd, loaded rears, w/loader, with 14 hrs on the meter three years ago. It's a keeper!!! Believe I would shop around some more.
   / L3800 price check #13
A Kubota dealer near me has two Mx4700's 2wd. One has 27 hours and the other has 63 hours. Both are rental returns and both can be had for 14,000. I think they still qualify for new financing and I'm sure they'd throw in loading the rear tires.
   / L3800 price check
Thanks for the replies. I'll definitely be looking around some more. This gives me a good direction to start.
   / L3800 price check #15
2wd and no loader, the price should be around 12K...
   / L3800 price check #16
I've recently ran into a few problems with my L3200 in 2wd even with loaded rears.
My barn now has a pair of pallet forks sized holes in the wall in back... I figured I'd be fine on a 5-7 degree slope dropping off a maybe 200lbs metal coral panel. I have loaded rears & that panel isn't even 20% of my rated lift capacity, so I didn't bother putting on my box blade for ballast. Well apparently that was enough to leave some nice skid marks because I wasn't in 4wd.
These new CUTs are designed & balanced for 4wd, unlike the old generation which was designed for 2wd with a lot more junk in the trunk. Unless its just pulling a mower on flat ground I wouldn't want a 2wd Kubota.
   / L3800 price check #17
yep, I agree completely.
   / L3800 price check #18
If no loader (FEL), these smaller tractors are fine in just 2wd. Add a loader & I want 4wd, But counter weight on the 3 pt is even more important... ;)
   / L3800 price check
So, I got a quote on a 4x4 L3800 that was a few thousand more, and after consulting my bank account, I think I'll just look for a heavier older tractor for my bush hogging. The B2320 with fel that I have should handle the rest. Thanks for the replies. Would have been nice to get a nice shiny new tractor, but I just can't justify the cost right now for the amount of use I'll get out of it.
   / L3800 price check #20
You can get good deals on the older iron. That's the road I would take for brush hogging.
2014 John Deere 544K 2 Wheel Loader (A47384)
2014 John Deere...
1997 John Deere 8100 MFWD Tractor (A52128)
1997 John Deere...
New Lewis Brothers MFG DB2 Poultry Housekeeper (A52128)
New Lewis Brothers...
Set Yield 360 Y Drops (A50514)
Set Yield 360 Y...
Payment Instructions (A47384)
Payment...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A50323)
2013 Ford F-150...
