joystick freezing up in cold weather
   / joystick freezing up in cold weather #21
I use to wrap a battery warmer blanket around my joystick and plug it in before using the machine.
It solved my problem.
Hey - I thought this was a family-friendly forum...
   / joystick freezing up in cold weather #24
Jayhawk this is what my caps look like with the hole drilled into them.
THANK YOU!!!! That helps a whole bunch. I will drill them out tomorrow and keep my fingers crossed that will take care of my problem.
   / joystick freezing up in cold weather #26
:confused:I don't think those are the caps you need to drill out,
it's the other end, it has two screws holding the cap on.
   / joystick freezing up in cold weather #27
You can do the caps on either end ( two on each end), but this was the cap that had held moisture and was freezing my joystick.
2012 PETERBILT 388 SLEEPER TRUCK (A51222)
2012 PETERBILT 388...
2022 Spartan RZ-Pro Zero Turn Mower (A50860)
2022 Spartan...
TOYOTA 8FGCU30 FORKLIFT (A50854)
TOYOTA 8FGCU30...
(INOP) VOLVO L70H WHEEL LOADER (A50459)
(INOP) VOLVO L70H...
Kubota ZD331 Diesel Zero Turn Mower (A50860)
Kubota ZD331...
Cable Sling (A50860)
