Loader Kubota b2320 3 fonction valves on loader
   / Kubota b2320 3 fonction valves on loader #1
Stihl22
Kubota B
Does anyone know if I can put a 3 fonction valves on the loader for a grapple on a b2320?
   / Kubota b2320 3 fonction valves on loader #2
If you have hyd , you can add a 3rd function valve for a grapple.
You could also use a diverter valve, which uses the curl hyd for the grapple using a solenoid operated valve with switch on the handle.
Hydraulics:
Type: open center
Capacity: 3.7 gal [14.0 L] (gear)
4 gal [15.1 L] (hydro)
Valves: 1 or 2
Pump flow: 4.7 gpm [17.8 lpm]
Total flow: 8.3 gpm [31.4 lpm]
Steering flow: 3.6 gpm [13.6 lpm]
   / Kubota b2320 3 fonction valves on loader #3
Check out some of the grapple threads. You'll get all your answers there.
   / Kubota b2320 3 fonction valves on loader #4
The factory does not offer a third function for the 20 series yet.
   / Kubota b2320 3 fonction valves on loader #7
That is the hyd delivery tube for the B2320 from the loader valve to the 3pt.
You have the same pipe #80 on your B2620.
Okay thanks! I will chek that in detail, because I want to build a grapple and a angle blade to remove snow to.
   / Kubota b2320 3 fonction valves on loader #10
I believe that is the same tube I removed to plumb in the line to and from my backhoe.
You may want to check the parts diagram at a Kubota dealer for the backhoe installation kit. Then do what I did which was buy the fittings for each end. Then plumb from there. That way you won't have to use compression fittings in an area that is difficult to get to.
If you are interested, let me know. I might have the diagram somewhere.
2015 Ford Taurus AWD Sedan (A48082)
2015 Ford Taurus...
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2008 Honda Civic Sedan (A48082)
2008 Honda Civic...
20 ft. Shipping Container (A50860)
20 ft. Shipping...
TOYOTA 42-6FGCU25 LP SIT DOWN FORKLIFT (A50854)
TOYOTA 42-6FGCU25...
JOHN DEERE 5205 TRACTOR (A51406)
JOHN DEERE 5205...
