Traction issues
   / Traction issues #1
Indygunworks
Indianapolis, IN
1980 Ford 340
I have 30 tonnes of recycled roadway base that need to be spread this week. The stuff is packed solid and is harder than **** to get a loader full. It took me 3 hours to spread 1/4 of a load at the front of the driveway, and that was where I already had base for traction. the remaining 1 3/4 loads needs to be spread in an area that is overly slick and I just cant seem to get a loader full. To make matters worse there really isn't an area where I can get much traction at all. I have a box blade that worked pretty well for the other spot, but I had traction on existing base ( was making the driveway wider)... In the next spot I will not be able to get enough traction to "pull" gravel from the pile with the box. Being on a time crunch I don't think I have many options. Any tips or tricks to getting this done?
Here is the space
and here is the pile
   / Traction issues #2
Can you add more weight to the tractor? Also, is spreading some sand an option?
   / Traction issues
I don't have time to fabricate adding weight, unless its a super easy method. spreading sand is not an option.
   / Traction issues #4
I have 30 tonnes of recycled roadway base that need to be spread this week. The stuff is packed solid and is harder than **** to get a loader full. It took me 3 hours to spread 1/4 of a load at the front of the driveway, and that was where I already had base for traction. the remaining 1 3/4 loads needs to be spread in an area that is overly slick and I just cant seem to get a loader full. To make matters worse there really isn't an area where I can get much traction at all. I have a box blade that worked pretty well for the other spot, but I had traction on existing base ( was making the driveway wider)... In the next spot I will not be able to get enough traction to "pull" gravel from the pile with the box. Being on a time crunch I don't think I have many options. Any tips or tricks to getting this done? Here is the space http://s659.photobucket.com/user/jacq220/media/Mobile Uploads/photo_zps6dfc06cb.jpg.html and here is the pile http://s659.photobucket.com/user/jacq220/media/Mobile Uploads/image_zpsbf60fb9a.jpg.html
Did you try scraping the mud down to dry around the pile?
   / Traction issues
No... Just stepping one foot into the area where the gravel needs to go gets you a boot full of sticky goo. I am thinking I am going to have to spread by driving over already spread gravel. Its to the point where I really cant even get much traction on the grassy area. The existing driveway base is the ONLY place I can get traction. I have 4 hours tomorrow morning, and one day next week to get this spread. I am wondering if I should bite the bullet and pay someone with a skid steer.
   / Traction issues #6
Might be cheaper and quicker to rent a skid steer and do the work yourself.
   / Traction issues #7
That or build a path from the pile with the material to where you need to spread it.
   / Traction issues #8
Do you have a tooth bar on your loader? That might lessen the force (traction) you need to fill the bucket enough to make it work.
   / Traction issues
No I do not... I am not sure where I could pick up a tooth bar, and get the install done before next week. Its on my list though.... but its a very very long list.
   / Traction issues #10
+1 on the tooth bar. Install is not difficult if you can find a dealer that has one already in stock. Just drill 2 holes and bolt it on. This will make driving into the pile very easy and you can then spread the material in front of you creating the non-slick area as you go.
SPRING TOOTH HARROW (A52708)
SPRING TOOTH...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2016 DODGE RAM 3500 FLATBED (A58214)
2016 DODGE RAM...
Bell 1600 Gallon Nurse Trailer (A56435)
Bell 1600 Gallon...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
