Good morning!!!!
   / Good morning!!!! #30,801
Currently 5 with a windchill of-6. Low -7. Dave can you come get your cold back?
Feed truck made it about an hour after dark. Had a wrecker with him just in case. Ended up not needing wrecker.
Stay warm everyone.
   / Good morning!!!! #30,802
Dave
Not quite that simple. That's the beginning of a 4x16 extension to 2nd floor of the cottage, 1/2 bath and mountain view lanai enclosed on 3 sides and roof.
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #30,803
2015-02-19, 0315
10 degrees right now...at least it's above zero. Today's high will be 21 with a little (1-3 inches) snow.
   / Good morning!!!! #30,804
Good morning all. Going to be a wet one today.
We got most of the sheep moved up to my friends farm yesterday.
Had a count this morning and only 56 left, so that's 3 more journeys with the trailer and then I'll be sheepless for a day or two.
Is "sheepless" a proper word in the USA ? Maybe, sure I once saw a film of that title with Meg Ryan in Seattle - and didn't see a single sheep.
   / Good morning!!!! #30,805
Perhaps best I don't show pictures of Max as he is not the typical pure bred black and white Border Collie sheepdog at all.
In fact he looks nothing like a sheep dog - small and brown and of mixed parentage.
He has been around sheep since being a puppy and while I know he is not a sheepdog, he doesn't and neither do the sheep.
I can't get him to "lie down", however he will generally respond to "Away" and quite often "Come by" .
Often he seems to simply sense which way I would like the sheep to move and then simply gets on with it without me interfering.
You might find some hints on dog control by radio here:
Country Calendar - Spoofs Special - Television | NZ On Screen
Towards the end there other a couple more hints on sheep farming practices too
   / Good morning!!!! #30,806
Farmer2009 - pleased to hear the feed wagon made it through.
Thanks, it needs some sheep. :D They used to raise a lot of sheep around here to supply the woolen mills (pre-cotton) and meat markets to the south (Boston, New York). Also, the Katahdin breed was developed not far from here. Breeds of Livestock - Katahdin Sheep
Read the wiki link to the Katahdin sheep. Their qualities sound so remarkable and versatile you really should get some and let me know if the claims are true.
If they are as perfect as wiki says, a little more selective breeding and they will soon be working the snow blower too ;)
   / Good morning!!!! #30,807
23 degrees, the high of the day, going down to 18, which likely sounds like Florida to some of you.
But added to that are high winds, up to 25mph sustained with 40mph gusts.
good day to stay inside, tomorrow too, and then temps zoom back up to 60 on Saturday in rain.
Not one flake of snow from last night's front coming through.
I've got one outside faucet at the barn dripping, will check on that later today. I had drained my hose reel assembly at the house, then the painter reconnected it several days ago without checking with me, washed out his latex paint bucket, and of course now all that water is in the plastic reel mechanism, likely testing the limits of plastic's ability to expand when that water inside freezes. I suggested afterwards, unfortunately, that he use the utility sink in the garage instead, and I got a belated look of understanding. Of course that then goes in my septic system so perhaps that's not such a good idea either.
Next winter I think I'll put the reel (or its successor...) in the garage. It's frozen into the ground now.
All of which is minor compared to the challenge of snow and dangerously cold temps some of you are having.
RS, glad you fixed your tractor. Can't imagine not having it, and you continue to amaze me at what you are able to fix/make/design.
While I was splitting some red oak in the last week I thought of you. And chuckled thinking: Now RS, here goes the wood into the woodpile where it will sit patiently drying out, so that come Fall like a fine wine, it will be at its peak.
And then I promptly burned some of it a few days later, and yeah, some of it hissed, but you get the fire going hot first, then dump on that slightly wet wood. It was dead falldown wood, so it had dried out, then gotten wet just laying out there of course.
I'm trying not to buy wood with all this wood around me, just have to go out and get it. Besides, it always burns better if you cut and split it. And when you get to that knotty knurly hunk, as you throw it into the fire waiting for the cracks and pops, you remember when you split it. Crack, grrrrrrrr, crack crack. Your tune may vary.
As we sit down to our pork chop tonight, utility stock investors are licking theirs...electric and propane bills are going to be ugly. C'mon Spring.
   / Good morning!!!! #30,808
5 this morning high of 16 or so later. When front came they got a wiff of snow then blustery and cold. Snow in forecast for Saturday rain Sunday and 50 degrees then 30s for Monday
Good Morning
   / Good morning!!!! #30,809
10 headed to 17. Got a dusting of snow on top of the 5 inches on the ground last night. Tonight headed to negative territory... -11 windchill.
   / Good morning!!!! #30,810
The cold and stormy weather will be around until about March 5 or so so. Several more snow chances for middle Atlantic south to South Carolina
BUSCH LIGHT NEON LIGHT (A58374)
BUSCH LIGHT NEON...
PALLET OF DISHES & MISC (A58374)
PALLET OF DISHES &...
Black Steel Diamond Plate (A55758)
Black Steel...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
Mohawk 12,000lb Two-Post Electric Auto Lift (A55851)
Mohawk 12,000lb...
