Power Beyond on Dual SCV Valve
   / Power Beyond on Dual SCV Valve #11
#6 is power beyond, #5 is return, and #4 is tank.
   / Power Beyond on Dual SCV Valve #12
As already suggested you should get the tech manual. Take a look at selectmanuals.com for a downloadable version for the $29.95.
I have included a picture of what I think you are looking for on the 5X10 tractors.
  • 5x10powerbeyond.pdf
   / Power Beyond on Dual SCV Valve #13
J_J
Could you please explain the function of a pipe plug in the PBY orifice? I understand the PBY but not the pipe plug.Thanks,Jim
   / Power Beyond on Dual SCV Valve #14
PB valves have either a PB adapter or a hex plug PB adapter.
Both of these devices separate the main gallery so the tank fluid flows through the OUT port, and the pump fluid flow through the PB port for downstream operations.
   / Power Beyond on Dual SCV Valve #15
J_J thanks for the reply. I'm familiar with the plug on the left but not the hex plug. Does one install hex plug deeper in valve to block an orifice then attach fitting for hose to valve body? Can this same valve be utilized as a closed center valve? If so can you explain the process? Thanks,Jim
   / Power Beyond on Dual SCV Valve #16
An example of the plug type would be a 5000 series tractor. The pressure line from the pump goes to the rockshaft valve. On the valve housing are three ports to be used for power beyond. When attaching hose to these ports, you remove the pressure port plug. Inside of this port is a tapped hole to install the pipe plug. This blocks oil flow to the rockshaft and diverts flow to the power beyond attachment. The return oil from attachment then goes back into the rockshaft to feed rockshaft through return port. The third port is for"tank". Some attachments need no resistance to flow. If return line is routed to tank port, the rockshaft will not operate. If the internal passage is not blocked the plug, nothing will operate since there would be two paths for oil to go and fluid will take path of least resistance.
   / Power Beyond on Dual SCV Valve #17
Thanks jd110 for the explanation.
Jim
   / Power Beyond on Dual SCV Valve #19
Yes, the hex plug does install inside valve that use this configuration. The galleries are separated with cyl flow going to the OUT port and pump flow continues downstream.
If you want CC, then install a plug in that PB port.
If the valve uses a PB adapter, and you want CC, then install a Plug in the PB port.
2020 JLG 1732 4x4 Rough Terrain Telehandler (A49461)
2020 JLG 1732 4x4...
Excavator Bucket (A50860)
Excavator Bucket...
2002 International 4400 SBA 4x2 (A49461)
2002 International...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
Metal Door (A50860)
Metal Door (A50860)
UNUSED Brown Metal Roof Wall Panels (A50860)
UNUSED Brown Metal...
