One wheel tractor?
   / One wheel tractor? #1
larryfoster
Cowansville, Pa
1949 Farmall Cub
I have a circa 1950 Junior Chief walk behind cultivator
The Junior Chief tractor was a single wheel walk behind built by the Great Lakes company in Rock Creek Ohio.
My dad used it for a while when I was fairly young but since then it has been in a corner of my chicken coop until several years ago.
Anyhow, my neighbor did get it running (after 50+ years) but I have a blown head gasket.
Would appreciate if anyone has suggestions on where I might find one.
Information on these engines is scarce as hen's teeth.
Model Kohler K7-2
Serial no. 209570
spec no. 3652A
Thank you
   / One wheel tractor? #2
You can buy gasket material and cut one yourself. Also you could cut out a piece of soft copper as well. I've done that for a couple old Tecumseh engines before. Sorry I can't help with buying a stock one.
Thanks for that suggestion.
Guessing that it should be copper and not cork gasket?
would you have any idea what thickness for the copper?
   / One wheel tractor? #4
I believe I used 24ga. I'll have to check after-work when I get home tonight to be sure.
   / One wheel tractor? #6
A head gasket needs to be capable of taking high heat therefore paper and cork is out.
Dead soft copper and aluminum would be OK as both are compressible and resist heat.
I did find at my local NAPA a suitable gasket material for head and exhaust gaskets so ask around.
Also there exists hi temp liquid gasket products that you could combine with a home made copper gasket.
For soft copper check out hobby stores as soft copper is often used in some art techniques. (Repousser is one)
Thank you.
I'll check those sources.
Would a copper gasket be better than the gasket material you found at NAPA, for example?
Sort of a follow up question.
Would you take the head (and block?) to check for warp?
   / One wheel tractor? #8
Heck why not both, make a sandwich with copper on both sides. That hobby shop stuff is thin.
If you have a good straight edge you can determine that yourself..
On small 1 cyl engines I have used emery paper in coarser grits and the cast iron surface of my table saw to true up and clean a head.
Thank you.
I'd like this to be a low budget operation.
It doesn't seem to have a ton of value if a complete restoration.
It's value to me is as the tool it was designed for
   / One wheel tractor? #10
Usually on the cast-iron head and block you only have to lightly sand it unless it's pitted with rust. They rarely warp. Atleast not enough to make a difference.
2020 Peterbilt 389 Tri-Axle Sleeper Cab Truck Tractor (A49461)
2020 Peterbilt 389...
2015 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2015 CATERPILLAR...
POLARIS RANGER 4X4 PROSTAR UTV (A51406)
POLARIS RANGER 4X4...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
UNUSED Stainless Steel Sink (A50860)
UNUSED Stainless...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
