starter turning backwards
   / starter turning backwards #12
Benxisdrive of starter faulty and slipping !
THIS,
or just stuck on the shaft , try tapping in in an outward direction and see if it will loosen up.
   / starter turning backwards #14
Wheres the OP?
   / starter turning backwards #15
New battery has post backwards to original ones, battery connected backwards causing starter to run backwards. Hope you haven't damaged the charging system.
Walt Conner
   / starter turning backwards #16
Walt Conner
Did you make it to the 4th post? :
Yes it had been running no problem. No problems. Hadn't replaced anything such as battery. Took starter off and two different friends helped me check it to discover it was spinning backwards.
Tarter 2 Horse troughs (A50860)
Tarter 2 Horse...
Killbros 260 Seed Conveyor (A51039)
Killbros 260 Seed...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2016 Chevrolet Caprice Sedan (A50324)
2016 Chevrolet...
2008 Big Tex T/A Utility Trailer (A50860)
2008 Big Tex T/A...
PTO Winch (A50860)
PTO Winch (A50860)
