Power wings for snow blade-converts to pusher
   / Power wings for snow blade-converts to pusher #2
Nice. Was going to ask why you needed the chains, for support or to attach to a winch to let the wings adjust back. Then I finally got the video to play.
Interesting concept. What is twisting the rod to lift the wings? Hydraulics, electric motor or linear actuator?
A 4" actuator moves a lever arm welded to the pivot bar.I had to make the arm short and made two L-shaped plates to stabilize the rod,to get enough rotational movement. The wings are 5/8 UHMW and the pivot rod is 3/4" steel with 3/4" all thread welded on each end.
Some closeup shots of the pivot ends.I used chain because I had it lying around.Could use wire,cable,rope,whatever.
Might be hard to see but there is a slot in the UHMW that a 3/8" bolt rides in to lift the end plates.The bolt is fastened to a short arm that's welded to the pivot bar.I drilled the blade ribs out to 7/8" and used brass flange bushings.
   / Power wings for snow blade-converts to pusher #4
I am impressed! I have skipped over this thread for a few days and just looked today, glad I did. Now you have me thinking. :thumbsup: Ed
   / Power wings for snow blade-converts to pusher #5
Glad you added that the wings were UHMW as otherwise steel would have bin a 'tad overkill' LOL.
Nice concept and workmanship. Clever.
I also have one wing, totally manual (but easy to remove) but very effective as I then have only one side spilling over.
I figure it saves me 40% time when cleaning larger areas.
I found that using one wing was more productive than angling my blade. Also angling tended to push the front sideways and play **** on the front wheels as I often needed to crab when the loads were excessive.
An added benefit was that the piled up snow looked neater and as well I could push and lift the 'loads' up and over.
   / Power wings for snow blade-converts to pusher #6
   / Power wings for snow blade-converts to pusher #7
Yes - I agree and very clever. You do nice work !
gg
This is a super construction locknut. You have a good mechanical mind.....and patience to see it through.
This was easier than some of my previous projects.The front disc brake project on a poorly conceived AWD Simplicity Prestige was a little tougher.A one piece wheel/rotor to keep the front wheeltrack as narrow as possible.In stock form this tractor,with hydraulic front drive,had the same downhill tractive ability as a two wheel tractor with no locking rear end.After the brakes were added it would stop dead in its tracks on a 35 deg bank.
   / Power wings for snow blade-converts to pusher #9
VERY nice work!
Fred
   / Power wings for snow blade-converts to pusher #10
I like the convertible plow /pusher idea! Nice work.
I put SAM wings on my RTV plow and it helps a ton. Just wish they were adjustable on the fly.
2021 JCB HM180T Hydraulic Breaker Excavator Attachment (A49461)
2021 JCB HM180T...
2018 John Deere 60G Excavator (A50490)
2018 John Deere...
2013 VOLVO VNL860 TANDEM AXLE SLEEPER (A51219)
2013 VOLVO VNL860...
2022 GTS FS35-G2 Flex Draper Header (A50657)
2022 GTS FS35-G2...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2008 Ford F-350 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-350...
