What is the best radiator flush and coolant??
   / What is the best radiator flush and coolant?? #11
I use Peak Super Cleaner Flush. Run for six hours then drain and flush with distilled water, run for 15 minutes then drain and add AF.
I clean the machine with a leaf blower after working in the summer.
One thing I did notice was the temp was rising before the flush and dropped back a bit but not back to normal. I found the thermostat was warped and not seating properly preventing the radiator from having enough time to cool it. Replaced the thermo and problem solved.
   / What is the best radiator flush and coolant?? #12
I did a thorough cleaning of my old Farmall radiator earlier this year.
First round was vinegar.
Then Muriatic acid
Then a Gunk brand radiator flush
Then Washing soda.
It was amazing what came out of that thing.
   / What is the best radiator flush and coolant?? #13
Hi all zetor 5043 putting out some water from top of rad but not heating up had head gaskets done about 1 yr ago any advice will I wash out rad Or could it be gaskets again .? Any comment welcome new to this as I am not high tech Paddy c
   / What is the best radiator flush and coolant?? #14
Then Muriatic acid
Then Washing soda.
Have not seen this type of flush before. How did you dilute these products
to flush the cooling system?
   / What is the best radiator flush and coolant?? #15
Does not sound good for the water pump.
1998 CATERPILLAR 953C CRAWLER LOADER (A52707)
1998 CATERPILLAR...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
CATERPILLAR 302.7CR EXCAVATOR (A52707)
CATERPILLAR...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2015 Ford Explorer AWD SUV (A55853)
2015 Ford Explorer...
