What to build? 72ft of 6" wide flat bar
   / What to build? 72ft of 6" wide flat bar #21
Keep posting your progress... even if it is awhile between posts. Lord knows how many projects we all have in various stages of work! :laughing:
   / What to build? 72ft of 6" wide flat bar #22
Every time I get a little too proud of my self a guy like you comes along and puts me in my rightful place. I have the same welder as you, but it has never produced anything that fine.
Can't wait to see your next project.
   / What to build? 72ft of 6" wide flat bar #23
   / What to build? 72ft of 6" wide flat bar #24
unfortunately, now i have to spend some $$ for the hydraulics to run it. Thanks to JJ's posts on solenoid divert valves, I should be able to get by spending minimal $$.
Or just use a rear remote. I used one for years. Loved it. Less fussy than diverter valve or 3rd function. Works just as well.
NICE!! Looks just like mine (which I did not build).
Actually the millonzi grapple was used as a reference point for me. Pretty sure your pics helped me out a ton. Thank you
I already have a 3 spool valve on the rear remotes for tnt and box blade ripper,etc..
   / What to build? 72ft of 6" wide flat bar #27
I'm sure you will love it once you finish and get hydraulics squared away.
Thank you for the kind words. Believe me, I am no fabricator. Notice no close-up weld pictures... To many critics and it will do the job I intend, if not ill grind and weld more.
Had help from TBN again earlier identifying a hydraulic fitting and now have the hydraulics all ordered.
   / What to build? 72ft of 6" wide flat bar #30
You should be really proud of yourself. I would be!
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
Yale 50LX Cushion Tire Forklift (A49461)
Yale 50LX Cushion...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
2000 PETERBILT 357 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
