What to build? 72ft of 6" wide flat bar
   / What to build? 72ft of 6" wide flat bar #21
Keep posting your progress... even if it is awhile between posts. Lord knows how many projects we all have in various stages of work! :laughing:
   / What to build? 72ft of 6" wide flat bar #22
Every time I get a little too proud of my self a guy like you comes along and puts me in my rightful place. I have the same welder as you, but it has never produced anything that fine.
Can't wait to see your next project.
   / What to build? 72ft of 6" wide flat bar #23
   / What to build? 72ft of 6" wide flat bar #24
unfortunately, now i have to spend some $$ for the hydraulics to run it. Thanks to JJ's posts on solenoid divert valves, I should be able to get by spending minimal $$.
Or just use a rear remote. I used one for years. Loved it. Less fussy than diverter valve or 3rd function. Works just as well.
NICE!! Looks just like mine (which I did not build).
Actually the millonzi grapple was used as a reference point for me. Pretty sure your pics helped me out a ton. Thank you
I already have a 3 spool valve on the rear remotes for tnt and box blade ripper,etc..
   / What to build? 72ft of 6" wide flat bar #27
I'm sure you will love it once you finish and get hydraulics squared away.
Thank you for the kind words. Believe me, I am no fabricator. Notice no close-up weld pictures... To many critics and it will do the job I intend, if not ill grind and weld more.
Had help from TBN again earlier identifying a hydraulic fitting and now have the hydraulics all ordered.
   / What to build? 72ft of 6" wide flat bar #30
You should be really proud of yourself. I would be!
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
2011 MAGNUM PRODUCTS LIGHT TOWER/WATER TANK TRAILER (A50854)
2011 MAGNUM...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A51039)
2018 John Deere...
