What to build? 72ft of 6" wide flat bar
   / What to build? 72ft of 6" wide flat bar #21
Keep posting your progress... even if it is awhile between posts. Lord knows how many projects we all have in various stages of work! :laughing:
   / What to build? 72ft of 6" wide flat bar #22
Every time I get a little too proud of my self a guy like you comes along and puts me in my rightful place. I have the same welder as you, but it has never produced anything that fine.
Can't wait to see your next project.
   / What to build? 72ft of 6" wide flat bar #23
   / What to build? 72ft of 6" wide flat bar #24
unfortunately, now i have to spend some $$ for the hydraulics to run it. Thanks to JJ's posts on solenoid divert valves, I should be able to get by spending minimal $$.
Or just use a rear remote. I used one for years. Loved it. Less fussy than diverter valve or 3rd function. Works just as well.
NICE!! Looks just like mine (which I did not build).
Actually the millonzi grapple was used as a reference point for me. Pretty sure your pics helped me out a ton. Thank you
I already have a 3 spool valve on the rear remotes for tnt and box blade ripper,etc..
   / What to build? 72ft of 6" wide flat bar #27
I'm sure you will love it once you finish and get hydraulics squared away.
Thank you for the kind words. Believe me, I am no fabricator. Notice no close-up weld pictures... To many critics and it will do the job I intend, if not ill grind and weld more.
Had help from TBN again earlier identifying a hydraulic fitting and now have the hydraulics all ordered.
   / What to build? 72ft of 6" wide flat bar #30
You should be really proud of yourself. I would be!
1997 Mercedes Convertible (A48082)
1997 Mercedes...
2014 Kinze 1100T Dual Auger Grain Cart (A50657)
2014 Kinze 1100T...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
JOHN DEERE 450H CRAWLER DOZER (A51406)
JOHN DEERE 450H...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
