What time of year to redo a yard?
   / What time of year to redo a yard? #1
JFoy
Clemmons/Lexington, NC
Kubota BX25D
Got an acre of land on about a 7degree slope that was a garden for years but has been fallow for the past five years. And during these past five years, it has just been brush-hogged every year. The ground is rather lumpy.
We're getting ready to build a new house and this field will be our front yard area. Not so much a question of how to work it up and level it but when? We're in the Piedmont NC area and the soil is considered sandy loam / wedowee.
My plan involves using the disc to break up the grass (maybe the tiller) and move some around with the box blade to smooth some rough spots.
This time of year, we can get heavy rains that might wash ruts and the like. As of late, we seem to get a short but heavy rain once to twice a week.
So, should I wait till the fall to cut it and reseed it or do it now and spread straw on it?
Thanks,
John
   / What time of year to redo a yard? #2
Seed germinates best when the temp is between 60 and 80 deg. Use a straw blanket on the slope.
   / What time of year to redo a yard? #3
This has been a weird year with excess moisture in the soil.
If you do not over work the soil, and loose all the moisture,,, do it now.
If you just GOTTA run a power 3PH rototiller,,, then wait 'til spring,,,
   / What time of year to redo a yard? #4
Rototilling will expose the weed seed, and lead weeds to grow
Use roundup to kill existing vegetation.
Fill the low spots
Fall is the best grass growing time
Fill the low spots
Are you saying you'd kill it off now, grade it, and reseed this fall?
   / What time of year to redo a yard? #6
Assuming that you will be planting fescue, your chances of getting a good stand are much better if you plant in the fall (mid- to late September, early October) rather than the spring.
Steve
   / What time of year to redo a yard? #7
Assuming that you will be planting fescue, your chances of getting a good stand are much better if you plant in the fall (mid- to late September, early October) rather than the spring. Steve
Agree, this way the grass gets two growing seasons before heading into the hot summer months
   / What time of year to redo a yard? #8
Steve
This...
I've always tried to re-seed between the 15th of September and the 15th of October...
Piedmont area of NC...
   / What time of year to redo a yard? #9
   / What time of year to redo a yard? #10
Start to kill now.
Can retreat any missed areas, then plant in mid September
As Steve said, have soil tested also
2025 Wolverine PRP-12-72W Ripper Attachment (A50860)
2025 Wolverine...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A51039)
2022 New Holland...
UNUSED Portable Double Bathroom (A50860)
UNUSED Portable...
2011 Liebherr L586 (A51039)
2011 Liebherr L586...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2013 FELLING  SKINNYNECK TA LOWBOY (A50854)
2013 FELLING...
