Box blade and Rotary cutter
   / Box blade and Rotary cutter #21
Setup a search filter on Craigslist directly. It has options for search nearby locations itself now. No need for 3rd party stuff. Can set the search filters to Email as well.
I appreciate all the responses. I have decided to stock with CL in light of all the different searches. I have come across many that I did not see before. If I can find heavy duty used, I will be thrilled.
   / Box blade and Rotary cutter #23
What's your price range?
I think I'm going to sell my land pride hrl 3578 with hydraulic scarifiers. It's 78" wide and weighs 981 pounds.
Shipping could be a killer but maybe not. I bought it from Texas and had it shipped to MA.
If you have hydraulic scarifiers we will not be in the same ball park. Let's just say there are a couple I'm looking at relatively close by that are 450-550. Appreciate the offer though.
Found a 6' Bush Hog 256 with this gear box. 1473383736809.jpg. On the listing the guy thought it was missing a stump jumper and blades [which it ended up having] listed it for $400. However I do need to buy a drive shaft for it. The bushhog sat for 2 years according to him. The gearbox seems to be in good shape after I had spun the blades and the gears got lubed . The more I spun it the more loose and free spinning it became. There might be a possibility of a leak at a seal, but the seals seem cheap to replace if it is a leak. The guy said he believes his workers put grease on spline to remove drive shaft, which he believes it is not a leak. I believe I have found a good deal, but need some thoughts on drive shaft.
Will also accept any opinion or input.
Thanks.
   / Box blade and Rotary cutter #26
A PTO shaft is a commodity item & about $150. Measure the length needed & take note of the shaft size & type on the gearbox then go to Tractor Supply to grab one.
Thanks, Fallon.
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
2011 International School Bus (A49461)
2011 International...
2018 JLG 1644 4x4 15,000lb High-Capacity Rough Terrain Telehandler (A49461)
2018 JLG 1644 4x4...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2007 FORD F-450 (A50854)
2007 FORD F-450...
