Chaining rear of tractor with implement attached to 3PH?
   / Chaining rear of tractor with implement attached to 3PH?
I chain as normal to the drawbar with the tiller up. Then lower it onto blocks and strap it down with one strap.
The blocks are always with me as I use them for wheel chocks on the trailer.
What dimensions are the blocks you are using?
   / Chaining rear of tractor with implement attached to 3PH? #12
I throw the strap over the lower 2 hitch arms and hook it forward so it pulls against the tires. I know that's not ideal, but it works.
   / Chaining rear of tractor with implement attached to 3PH? #14
Chaining rear of tractor with implement attached to 3PH? I dont understand the question so I must not have that problem, Ayuh....
With an implement attached and lowered onto the trailer, the implement is in the way of where the chain would run from a clevis on the drawbar to the stake pockets
   / Chaining rear of tractor with implement attached to 3PH? #16
So is this about chaining down a tractor to/on a trailer for transport with some sort of implement/attachment hooked on? If so, know wonder I didn't get it, I don't have a trailer, yet........
   / Chaining rear of tractor with implement attached to 3PH? #17
I wrap my 4 chains around the axles just inside the tires and stretch to the trailer frame and strap the implement down.
2005 Toyota Corolla Sedan (A48082)
2005 Toyota...
2018 Toro Sand Pro Bunker Rake (A49461)
2018 Toro Sand Pro...
2013 HINO 388 (A50854)
2025 K1119 UNUSED Metal Carport (A50860)
2025 K1119 UNUSED...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
