7' or 8' Implements for 50hp
   / 7' or 8' Implements for 50hp
Total length behind the tractor may become an issue. If you are only in wide open space, shouldn't be a problem, other than that, you may have problems with a 7'. Most people tend to stay away from the 7 footers.
You may want to consider loading the tires. Since they are not currently, try everything out as is. But if you ever seem lacking in traction or stability, load them for sure. You will think that you are operating a different machine besides making the tractor ride much smoother.
The reason I didn't opt for loaded tires is that I read that you shouldn't when you have a backhoe, which I do have. I kind of figured I can always get them loaded later but wasn't sure about the backhoe. Also how does this effect finish mowing when loading the tires? Obviously a wet ground it will be an issue but that is the case loaded or unloaded.
   / 7' or 8' Implements for 50hp #12
Except for the finishing mower & landscape rake...I would stick to 6'.
If you mow tall grass with the rotary cutter, or till hard soil,you'll be happy it's 6' and your still able to move along at a decent speed.
Other thing is the weight of the machine on the 3 point of a smaller machine.
   / 7' or 8' Implements for 50hp #13
I run loaded rears on my Workmaster 50 and finish mow. I don't mow wet and I don't turn sharp. My ground is hilly and the added stability is welcome plus using the FEL it's needed. Since you have a backhoe no need to load the rears but I would guess your backhoe usage will be much less than mowing.
   / 7' or 8' Implements for 50hp #14
My tractor is 5 foot wide and I wish my mower and rotor tiller was 6 foot wide. Any slope and it doesn't cover both tires. Also it will keep you off fence lines with the tires.
Keep that in mind too when deciding on size.
   / 7' or 8' Implements for 50hp #15
If money is no object, go to the JD site and look at their implements. In particular is their 6' cutter listed for their 4052 model tractor (52 engine hp). A neighbor just bought both and I assure you, it will put you and your grandchildren in the grave.......Personally I wouldn't put more than a 6' on that tractor and if it's the one I mentioned, I surely wouldn't.
   / 7' or 8' Implements for 50hp #16
Why not load tires on a backhoe? My dealer suggested it and loaded mine at no charge. I've had no issues.
   / 7' or 8' Implements for 50hp #17
There is no reason you "can't".
It's just not normally required with the weight of the hoe being plenty sufficient.
   / 7' or 8' Implements for 50hp #18
My 51 HP, MX5100 Kubota will handle 8' so wherever possible that's what I do. My 8' landscape rake works so much better than a 6'or 7' would.
There is a thread in here from a few months back but some manufactures have it in their manuals not to use loaded tires with a BH. The topic then turned to possible warranty issues by having loaded tires with a bh since the manual stated not to do it. Brings up another question, other than wheel weights any other ways to add weight when using an implement when the BH is off?
Another question, with 8' implements I'm seeing most are cat 2. My LS has a cat 1 hitch. What would I need to convert the cat 2 implement into cat 1?
   / 7' or 8' Implements for 50hp #20
Three ways to add weight to the back
1. loaded tires
2. wheel weights
3. something heavy on the 3PH. Ballast box, box blade, rotary cutter, etc
To make cat 2 implements work on cat 1...you need to replace the pins on the implement with cat 1 pins.
2004 Porsche Cayenne AWD SUV (A48082)
2004 Porsche...
2006 GENIE GTH6622 TELESCOPIC FORKLIFT (A51242)
2006 GENIE GTH6622...
Headache Rack (A50860)
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
Bad Boy Outlaw XP61 Zero Turn Mower (A48082)
Bad Boy Outlaw...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
