What Spare Parts do I Need to Keep on Hand
   / What Spare Parts do I Need to Keep on Hand #1
1Crossbow
Erie, PA
Mahindra 2538
I am new to the world of Tractors and just purchased a Mahindra 2538 to maintain my driveway. I have a front snowbower, box blade and rotary cutter? I bet I will need some spare shear pins, oil and hydraulic fluid. What other parts break that i need to stock up on.
   / What Spare Parts do I Need to Keep on Hand #2
Lynch pins, can't have enough of them.
   / What Spare Parts do I Need to Keep on Hand #4
I always keep,fuel filters and oil filters+fluilds on hand.Don't know how cold it gets but Powerservice in your fuel can save some head aches.
   / What Spare Parts do I Need to Keep on Hand #5
Lynch pins, shear bolts, a set of filters, extra key, if a cab model, an extra cab filter and wiper blades
   / What Spare Parts do I Need to Keep on Hand #6
Filters, a set of grease zerks, spare fuses at a minimum
Thank you for the advise, i will stock up when I get my tractor in 2 weeks.
   / What Spare Parts do I Need to Keep on Hand #8
When I bought my tractor, the price included a spare set of every filter that it needed. I always keep lynch pins, spare 3PH pins, spare grease cartridges, and even a spare grease gun, several gallons of the correct motor oil and plenty of diesel fuel, spare fuel filter for my fuel pump and lots of bolts of various sizes although it seems I never have the one I need even with 3 bolt tray bins full. A tool for putting liquid ballast in your tires might be a necessity, it was for me.
The one filter that I didn't get was for my cabs filtration. After 5 years of use, I finally decided to clean them and they were still clear and clean. I don't suspect that I will ever need to change them out in my lifetime.
   / What Spare Parts do I Need to Keep on Hand #9
I would also suggest that as soon as you can afford it, get a large fuel storage and pump system. My 100 gallon tank with 12 volt pump has really paid for itself in ease of fuelling and cutting down on potential for fuel contamination.
   / What Spare Parts do I Need to Keep on Hand #10
This is what I have ended up with as the basics.
Oil Filters and (2) Fuel Filters and one air. I have a few "walk out hoses" - long hydraulic hoses (in 1/4, 1/2 and 3/4 which my machine has) that I can hook into the system when I blow a hose and walk out of the woods. One spare fan belt. Pins and keepers (my tractor does not really use them but you will). I store my fuel in a 50 gallon with an electric pump. Luv it. But I do not put any additives in the storage, only in the tank as it messes with the filters on the storage tank. Tons of oil, and a couple of spare lubes.
I also buy by the case degreasers and brake cleaner (spray).
One thing, tractors break. Not your fault, not the manufacturers. They just do. If you are handy, get yourself a good basic toolbox.
2011 Chevrolet Traverse 1LT SUV (A50324)
2011 Chevrolet...
IH 686 Tractor (A50514)
IH 686 Tractor...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2015 JOHN DEERE 35G EXCAVATOR (A51242)
2015 JOHN DEERE...
2013 Ford E-250 Cargo Van (A50323)
2013 Ford E-250...
