Improving the visibility of oil on an engine dipstick
   / Improving the visibility of oil on an engine dipstick #11
Centre punch a few dots along its length,works for me and takes but a minute.
   / Improving the visibility of oil on an engine dipstick #12
Just sand the back side with fine sand paper. Going on the second year since oil change on the 20KW Generac oil is clean and no moisture since I turned off the quite exercise.
David
   / Improving the visibility of oil on an engine dipstick #13
I have had some dipsticks that were hard to read, especially in low light situations. I have a piece of blackboard chalk and just put a bit on the stick and then stick it and read it easily. I don't do it all the time and I have never fried an engine. I just always make sure I have oil in them and change the oil out often. The best wrench you can have is clean oil.
Thanks for all the suggestions.
I'm inclined to try darkening the dip stick by heating the end and hopefully improve the contrast between the stick and the oil.
B. John
   / Improving the visibility of oil on an engine dipstick #15
That's what I do; does not have to be heated "red hot'. I use a propane torch and watch for the color change
   / Improving the visibility of oil on an engine dipstick #16
Paint the dipstick pink, that ought to do it.
   / Improving the visibility of oil on an engine dipstick #17
Well, I reckon I will sand it a bit, punch some letters and dimples onto it, drill a few little holes, heat and dip it in cool water, then paint'r pink. If'n that don't work, I'll get me some bi-focals. ;-)
prs
   / Improving the visibility of oil on an engine dipstick #18
prs
If you do all that it will break off while leaving paint in the oil.
Lots of good suggestions. Avoid paint and choose other options in order of least mechanical effect and ease of reversibility if they dont suffice.
   / Improving the visibility of oil on an engine dipstick #20
Not the least of which is laying the unmodified stick on a clean paper towel.
2002 FORD F-350 XL SUPER DUTY FLATBED TRUCK (A60430)
2002 FORD F-350 XL...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
1968 Fiat Allis 10c Dozer (A56438)
1968 Fiat Allis...
