135 Locked up on startup!
   / 135 Locked up on startup! #11
Ok Which one is the gearbox filler hole? I just tried again and as soon as you feel some resistance in the clutch i can turn the engine over. In the top 1/3rd of travel i'd say. That and the fact that i was able to roll the tractor with my trucks help tells me its not stuck in a gear. I think?
I think you locked it in gear AND sheer the sheersleeve that connect the box to the diff ?
I wouldn't be able to roll it if it was locked in gear though right? I took this pic through the hole. It appears to move between gears ok. This pic is neutral.
Yes for the left rail!
And the big gear ?
The one on the left of the pic? It moves back and forth with the lever. And i'm in Belleville, Ontario Canada.
Hey ya still :( Check this out. I found these marks / cracks with a Borescope. This is looking forward from the fill hole. This has to do with the Multipower I think?
2018 Kubota RTV500 4x4 Diesel Utility Cart (A55851)
2018 Kubota RTV500...
2012 Ram 3500 Crew Cab Flat Bed Truck (A56858)
2012 Ram 3500 Crew...
Wooden Rocking Chair (A55853)
Wooden Rocking...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
2000 CATERPILLAR 322BL EXCAVATOR (A52707)
2000 CATERPILLAR...
