X10 Upgrade
   / X10 Upgrade
The 2477s is a dual band device, it has RF capability as well as powerline. Depending on distance, that can be a good option for the outbuilding on a separate power feed. I have some of the 2477s in my config, and agree the manual can be a little daunting as it covers pretty much every electrical configuration you could encounter when installing the device....
To make it work like a 3 way switch between the house and the outbuilding the part that isn't clear in the manual is the house 2477 would not have a load directly attached to it as the load will be triggered remotely via signal to the switch in the outbuilding. Under that scenario you'd wire the house 2477 for hot/neutral/ground and cap the load wire. The outbuilding would then be wired as a normal switch with the lights attached to the load. Then configure the 2477s as controller and responder. If you have a hub you can also set schedules so they come on/off relative to the sun or in response to other sensors (ie motion activated).
Probably would need the powerline approach since shed isn't friendly to RF (double metal walls). If I go with Insteon I'll order 2 of the 2477s. Setup one as the controller in the house and the other as the responder in the shed. Looked at the wiring diagram and it's incomprehensible, more wires than the X10 (black and white only). That might be a deal breaker? :confused3: Don't have a Hub. Will investigate more Insteon applications if/when that protocol solves the flood light problem.
   / X10 Upgrade #22
I'll add my vote for zwave with a samsung smartthings hub.
   / X10 Upgrade
I researched Z-wave for about an hour today. From what I could find out it's completely wireless, no powerline usage. Is that true? If so, have concerns it wouldn't be reliable to reach shed at 150 feet with double metal walls plus walls of house.
   / X10 Upgrade #24
I'm sure it's not RF. The shed doesn't like RF since it 150 feet from house and has double metal walls. The controller in the house is Leviton Cat. No. 6319-1W. Don't know the shed responder number. Contacted Leviton about the 6319-1W they said it has been DISCONTINUED and they do not make a replacement.
That's old! You can get a different controller for x10. Doesn't have to be the same.
   / X10 Upgrade
I've decided to deep-6 all X10 stuff and upgrade to newer protocol.
   / X10 Upgrade
Decided to replace X10 with Insteon protocol upgrade. Ordered 2 of the 2477S switches today from smarthome.com. Normal price was $50 each but with Labor Day 30% off sale (8/30 to 9/3) got both for $70. :) Delivery in 2 to 7 days.
Remote Control On Off Switch White | Smarthome
   / X10 Upgrade #28
Each z-Wave device acts as a repeater. So only the farthest device away from any other may have a problem.
   / X10 Upgrade #29
Insteon is also compatible with X10, so you may also find a use for some of your old X10 stuff.
   / X10 Upgrade
Is it true that Z-Wave is completely wireless?
I will keep the X10 switches for possible future projects. :thumbsup:
John Deere Gator UTV (A50860)
John Deere Gator...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A48082)
2022 K-Z Sportsmen...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
