Asphalt over concrete driveway, would you do it?
   / Asphalt over concrete driveway, would you do it? #1
kcflhrc
Kansas
2013 John Deere 3032E
So I was thinking of getting a bid to do asphalt over my concrete driveway. Not much there really but the concrete is getting bad. It's basically a double car garage width and approximately 25' long then it turns to gravel. Concrete tear out and replacement is around $5k. I think this might be a much cheaper option but not sure of the issues that may come with it. Thoughts?
   / Asphalt over concrete driveway, would you do it? #2
The biggest issues would be if the existing concrete is heaving or settling, because that would continue and crack the asphalt in those areas. If it's all surface issues on your concrete, I think asphalt is a good option. A reputable paver will be able to give you a better idea when they see it.
   / Asphalt over concrete driveway, would you do it? #3
Yep- concrete, asphalt or simple gravel all require a proper base. Adding something over the top of something that is failing will lead to further failure.
Kinda like painting with no prep work- looks good for awhile......
   / Asphalt over concrete driveway, would you do it? #4
if the concrete is in good condition and stable then it should be fine....they put asphalt over concrete on highways all the time......but if the concrete is in bad condition, breaking up or settling then it would be best to remove it.......new asphalt will only be as good as the base it's being put on.......+1 on talking with a local reputable paver.........Jack
   / Asphalt over concrete driveway, would you do it? #5
I've seen products that just go over the top of the concrete to resurface it. It's a concrete product itself so I would imagine the bond would be decent. I've never used it, but it seems like a good option and less expensive. Maybe it's just another snake-oil product...
   / Asphalt over concrete driveway, would you do it? #6
Product is good! Used to change color or to allow stamp/design. Typically under 1/2” thick.
   / Asphalt over concrete driveway, would you do it? #7
Will extra height cause any problems. Attached garage
   / Asphalt over concrete driveway, would you do it? #8
+1:thumbsup:
   / Asphalt over concrete driveway, would you do it? #9
I have a concrete drive; my neighbor has an asphalt drive. There is no comparison in the esthetics, in my opinion. The asphalt just doesn't compare. I had mine replaced, with a faux brick edging, and it looks good. Twenty years and counting. I had several estimates, from $7000 down. The guy that did it, came back and said "It's the holidays, the homebuilders have shut down, my crew needs something for Christmas, I'll do it for $4500. I said "sold". They were professionals...took out the old concrete, did the leveling, laid the reinforcement, built the forms in one day; finished pouring and finishing the next day. I'm happy. I wouldn't have put down asphalt if it had been free...but like they say, a difference of opinion is what makes a horse race!
   / Asphalt over concrete driveway, would you do it? #10
Concrete is much more durable for sure, it's the economics for most people.:thumbsup:
WHITE CI-7 DRAW WORKS POWERED BY TWIN DETROIT 12.7S (A50854)
WHITE CI-7 DRAW...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2013 Ford Expedition 4x4 SUV (A49461)
2013 Ford...
3-Point Water Well Drill w/Drill Pipe (A50860)
3-Point Water Well...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
Diesel Fuel Tank (A50860)
Diesel Fuel Tank...
