Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #1
AchingBack
Southern Oregon
Mahindra 2615HST
Has anyone rebuilt or repaired this jack? Mine is leaking at the bottom of the rods going through the springs. I guess there must be some failed O-rings, or seals.
Without some guidance, I can't see how to properly tear it down. 1.5 Ton Aluminum Racing Floor Jack with Rapid Pump(R)
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #2
I have one, as far as I am concerned its junk... Will hardly lift corner of Chevy PU to change a tire...
But if you must....
https://manuals.harborfreight.com/manuals/60000-60999/60569.pdf
Note this statement in PDF file... IT probably in reference to part you need to repair....
572910d1538333125-pittsburgh-1-1-2-ton-jack-jpg
Dale
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #3
But if you must....
Mine lifts my big Thunderbird with no problem.
Dale
Thank you, but I already have this and it isn't helpful. Mine works when properly bled and refilled. It just leaks soon after.
If you search it on u-tube you might find some information about them... Worth a shot.
Lots of videos there on other floor jacks, but all of them are of a different configuration.
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #6
   / Pittsburgh 1 1/2 Ton Aluminum Racing Jack Leaks #7
Seals are pretty generic. If you can get it apart, you can probably find an appropriate seal at McMaster-Carr.
Thanks. At this point in time it is easier to deal with refilling and leaking. I don't have the time to tear into it without guidance.
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
Kivel 48'' pallet fork attachment, 3500# capacity (A53421)
Kivel 48'' pallet...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A52377)
2015 Peterbilt 579...
2005 NEW HOLLAND DC95WT CRAWLER DOZER (A51406)
2005 NEW HOLLAND...
TRUCKING INFO (A50775)
