running my own propane line?
   / running my own propane line? #21
I believe in Conn you need to be a licensed Plumber or LP installer to install LP gas piping. You'll needs permits pulled for both the piping and the LP Tank. The town plumbing inspector and Fire dept. will inspect the job and sign off on the permits. No gas company will fill your tank without proper permits. I'll assume you are purchasing a 100gallon tank not a 100lbr...??...Purchase a ASME tank as they do not have to be re-certified. This is how Mass does it and I'm almost positive its the same in Conn.
   / running my own propane line? #22
If its a 100 lb tank it can be inside the place where the heater is, does not need to be outside
   / running my own propane line? #24
You think he's gonna blow himself up or what?
I have no idea. I have seen it happen from DYI .
I have seen DIY plumb a house with PVC.
Was in the business for a long time. Ain't much I hadn't seen
   / running my own propane line? #25
A 100 lb tank is classified as a portable tank. I have 2 of them and take them to a refill place for filling
   / running my own propane line? #26
Even if it's allowed I still wouldn't advise it.
   / running my own propane line? #27
Maybe not, but these come with a 15 foot hose and are designed to use in a barn, garage or other such place
   / running my own propane line? #28
We have two tanks. The one at the shop the company would run X # of free for free. I helped them set and level the tank and the installer ran the line about 25' into my shop and never changed anything. The second tank I already had the main lines run (50' to the house) and buried so the installer just did the hook up and pressure tested everything for me and I paid for a few fittings at the tank and some at the generator. Very reasonable - thinking I had under $100 in everything and that also included a little run of copper from the regulator to the generator itself.
   / running my own propane line? #29
best I remember, the decal on the tanks state do not use indoors (or something along those lines)
   / running my own propane line? #30
Getting blown up by a leaky propane tank isn't even at the bottom of my list of things to try.
UNUSED Black Steel Diamond Plate (A50860)
UNUSED Black Steel...
2025 JMR 36in Mini Skid Steer Bucket Attachment (A50322)
2025 JMR 36in Mini...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
2023 QUALITY CARGO 16 T/A ENCLOSED TRAILER (A50854)
2023 QUALITY CARGO...
2019 Toro Proline 32in Fixed Deck Mower (A48082)
2019 Toro Proline...
2007 Ford Crown Victoria Sedan (A50860)
2007 Ford Crown...
