EddieWalker
Epic Contributor
Is your land flat or will the water line be going up hill or down hill? This affects how much water pressure you will have more then anything else.
How expansive is your soil? Talk to the guy at the Water Department to find out what type of pipe they use and recommend. They might not even let you use other types of pipes. Here, black polly was used for a period of time and now it's failing so often that the City of Tyler has two crews out working 24/7 in winter to fix the leaks. When wet soil freezes, it expands and breaks pipes buried in the ground when they come up to the meter. I personally think black polly is the worse stuff out there. As others have said, if you use PEX, up size it at least to the next level. If your soil is expansive, then gasketed pipe is the best choice, and what I expect the Water Department uses and recommends. Gasketed pipe slides into each section and allows the pipe to move while in the ground without leaking. It's what is used in every city in my area of East Texas.
With a 1 inch meter, you will probably have to use 2 inch pipe since that's the smallest that I'm aware of. Pacific Plastics Inc. >> Potable Water SDR’s White Gasketed
