IS THERE A WAY to have both.....
   / IS THERE A WAY to have both..... #1
CMV
NC
Kioti NX4510HST (previous LS XJ2025H, JD 500C)
A hydraulic and manual/standard toplink installed at same time?
I like my hydraulic toplink for box blade, but it is an absolute nightmare for a bush hog - leaks down so fast the bushhog ends up riding on the tailwheel over rough terrain and mangling the fork. So I'd like the hyd toplink in place for times its useful, but for bush hog or tiller that I want to set once and forget, I want the standard kind of manual toplink.
Seems it would be cumbersome to keep swapping them out, but don't really see a way they could both fit without one being in way of other. If they could coexists side by side, that would be sweet!
What would really solve my problem (and no idea if such a device exists) is a hydraulic toplink cylinder that can lock. Set it, then lock it with a set screw or something so it can't move. Would probably just hit the control & break that if it had it....
   / IS THERE A WAY to have both..... #2
Cheapest way, adjust the cylinder as needed and then unplug the rod end coupler. You should be good to go for all day and longer.
Second choice, get a double piloted check valve for your top link similar to what is pictured in this link.
   / IS THERE A WAY to have both..... #3
On my tractor, I have three holes vertically to mount the top link into. This is just an adjustment for the angles and for the draft control I believe. I do not see why you couldn't mount a hydrolic top link to the top hole and have it 'hung up' when not in use, and use a manual link on the bottom hole, hanging down when not in use.
That is, if you have those vertical adjustment holes.
I think I do, but wouldn't the lower one always be in the way of the higher one?
   / IS THERE A WAY to have both..... #5
Well, only one will be hooked up to the implement at a time.
The way envision this happening is say you want to use they hydraulic top link. When hooking up to the implement, simply let the mechanical top link dangle below, maybe secure it to something with a bungee to keep it from bouncing around. That should clear anything in the way of the hydraulic top link. It would dangle down by the PTO.
If you wanted to use the manual top link, simply hook up with the manual one and hang the hydraulic top link up outta the way. My tractor has a hook just for this.
When I let my top link dangle, which is rare, it doesn't seem to interfere with anything. However, I do not have this setup like this at all. This is just how I would start if I wanted to keep both hooked to the tractor and swap them out. The only way to see if it would work, is to hook it up and see if there is the potential for anything to bind or get in the way.
   / IS THERE A WAY to have both..... #7
Yep, unplugging does work well. Mowing and tilling tends to make a mess of the couplers though, even with caps. I’ve been looking at flow control valves, thinking of closing them completely to lock. I think these check valves would be better.
   / IS THERE A WAY to have both..... #8
Use the hydraulic top link, but use a parallel check chain or cable to keep the top link length to a pre-set maximum.
Bruce
This thread is making me feel dumber.....
How does the check valve work? I don't mean how does it physically block the flow of fluid in one direction.....I mean when I later DO want the cylinder to extend, how do I control the hyd toplink cylinder with that in place?
Check chain.....wouldn't that want to attach at the exact same places the hyd toplink is attached? Will have to look at that next time I'm at the tractor to see if a good place at both ends to do that.
   / IS THERE A WAY to have both..... #10
The check valve stops the flow when the cylinder moves the fluid. It 'opens' when the supply from the tractor opens it. Meaning, you dont need to do anything but move the lever inside your tractor. The cylinder may bleed down over a longer period of time, but not while your running it.
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
1988 23ft Center Console Fishing Boat with 25ft T/A Boat Trailer (A48082)
1988 23ft Center...
2014 Chrysler 200 Touring Sedan (A48082)
2014 Chrysler 200...
2013 Fiat 500c Lounge Hatchback (A48082)
2013 Fiat 500c...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
2008 FORD F-450 (A50854)
2008 FORD F-450...
