Good morning!!!!
   / Good morning!!!! #100,841
Generator info:
This is a Kohler 14RESA, 14kw, propane. Normal warranty is 5 years/2000 hours, or 18 months/1000 hours off grid.
Seems both Kohler and Generac are much less generous in their off grid offerings. Only certain models allowed.
We are off grid. Primary purpose of generator is battery charging. Currently that is happening every day for us lately. Don’t know if my orphaned, bankrupt batteries are beginning to fail (not holding power thru the night), a gremlin in the system, or a setting needs tweaking. So at this point generator does run a couple hours daily.
This generator replaces the 24kw diesel that wife’s washer didn’t like. It is a companion for my 10kw MEP 803A diesel. Rationale for choice. Concerned with ‘whatif’. Not getting any younger and when I’m no longer capable, was concerned wife can manage. No way I expect her to hump 5 gal cans of fuel. Propane I was able to extend line from current tank (remember my summer challenge) so propane delivery takes care of fuel. This is in addition to the 500 diesel storage I set up earlier, giving great redundancy. I’ll figure out a shared use schedule.
Setting up this generator has taken longer due to wife’s suggestion for space utilization - move the MEP. Doing so requires a whole new wiring scheme, being able to choose which generator runs. Takes a bit more thought when using current conduit runs in concrete. This one exhausts out the side, so I decided to install an exhaust fan in the wall that will be powered on whenever generator runs. Just using an old box fan for now, but will likely replace with something more permanent when I install the upper concrete board (after I get Tundra back).
This setup requires a custom transfer switch that allows which gen supplies power to my inverter/chargers and a component to select which gen is activated by Autostart call from the Outback. While I had previously built one for earlier setup, couldn’t resist trying to improve. This needs to be near foolproof, not only for wife but times we may have a housesitter.
This is what I have so far
Mostly done except breaker interlock and tidy up. Haven’t started on Autostart relays yet, just hooked into old setup for now.
This Kohler is a bit quieter than the big diesel. Wife commented she couldn’t smell it.
   / Good morning!!!! #100,842
Nice truck, Buppies. Bet you’ll be quite happy with it. Any reason for 3/4 vs 1/2 ton?
   / Good morning!!!! #100,843
Toyota discussion.
We have had a number of Toyotas over the years. No complaints. Compared to my last GMC, very happy.
Up to this point, any Tundra problems have not been Toyota faults. Only 2 major issues had to do with rodent damaged wiring. I honestly think this current problem may be also. A certain black cat maybe living too charmed a life!!!! Of course I’ve mentioned this to the service people, but but sure if the tech got the info.
Somewhat interesting, wife kinda chided me for not getting a new truck as she suggested. But I did get my new tractor
   / Good morning!!!! #100,845
1.93 “ of rain since 6 this morning, .63 in the last hour, gotta go to church in a couple of minutes.
Went to visit mom and Ellen’s dad already.
   / Good morning!!!! #100,846
Toyota discussion.
If you need a mouser, make sure you get a female cat or two. Get them "fixed". Males get lazy and stop mousing.
   / Good morning!!!! #100,848
David- I hope the techs figure out your Tundra's electrical gremlins soon. I am totally fascinated with your and Sophie's "off the grid" living and all your projects and system backups supporting the operation. Thanks for sharing. :cool:
It seems that my vehicular corrosion problems increased when MA started using more de-icing chemicals than just salt and sand; but I sm not sure.
It was not supposed to get this far north and west, but we did get some light rain showers this PM = sitting in my easy chair by the wood stove nodding off while watching/listening to today's football games and "chumming" for ticks.
   / Good morning!!!! #100,849
53F cloudy with on/off rain sprinkle.
Couple small projects done even took back pack blower for walk.
Just about every time I turn around Jake turkey was close by...hmm.
Watch some football nascar from recliner until pillow time.
Enjoy the evening all.
NEW Woods 6ft Finish Mower (A57024)
NEW Woods 6ft...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Caterpillar 6-cylinder Turbo Diesel Engine with Transmission (A55851)
Caterpillar...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
