PIcking up acorns and hickory nuts...suggestions requested
   / PIcking up acorns and hickory nuts...suggestions requested #11
I can just hear the hickory nuts falling from the tree, 75 feet up, and falling and gaining speed until it hits a 250 gallon propane tank that's sitting underneath it. Wow! Thought the tank had exploded. So, I moved the tank.
   / PIcking up acorns and hickory nuts...suggestions requested #12
We have the largest most powerful cyclone vac and it wont pick up the acorns, a few but not many.
But its wonderful for leaves. We have over 120 oak trees on the property and the leaves can get a foot thick.
   / PIcking up acorns and hickory nuts...suggestions requested #13
Tedious but my Stihl BR600 blower will move them. It helps if the grass is shorter. I was only moving them up to about 15 feet towards my fence line to get them off of the pasture.
One would have thought that the area would be overrun with squirrels who thought that they had died and gone to heaven but they just laid there to decompose if I did not blow them away from the fence.
   / PIcking up acorns and hickory nuts...suggestions requested #14
I also have the BR600,, it moves the nuts where the grass is short,,
I just read about the NEW BR800,,, I think it was Consumer Reports,,
They said the BR800 would blow a 4.6 pound brick across a concrete driveway, effortlessly,,, :dance1:
   / PIcking up acorns and hickory nuts...suggestions requested #15
A pig or two works great depending on the acreage. They taste better than corn fed hogs.
   / PIcking up acorns and hickory nuts...suggestions requested #16
Hmmm...instead of smoking them with hickory, you're ingesting them? Brilliant!
   / PIcking up acorns and hickory nuts...suggestions requested #17
I also have a BR600, my back/shoulders hurt even more thinking about an 800 :D
The BR600 is pretty powerful though.
   / PIcking up acorns and hickory nuts...suggestions requested #18
I cut my lawn low at end of the year so back pack blower can roll acorns apples away into piles for wildlife.
   / PIcking up acorns and hickory nuts...suggestions requested #19
Check out Bag-a-Nut. 36" Pull-Behind Large Acorn Picker
edit: ooops, I didn't see this was listed earlier.
I would try a HD lawn sweep. Might even remove the bag part of an old sweep, and mount the sweep on the front edge of a FEL bucket so it loads directly into the bucket.
Is HD, Home Depot?
I wish someone would invent a backpack blower that was also a vacuum.
377780 (A48837)
377780 (A48837)
71061 (A49346)
71061 (A49346)
2019 Isuzu NPR-HD 24ft. Box Truck (A50323)
2019 Isuzu NPR-HD...
2018 WACKER NEUSON CORPORATION DBA WACKER NEUSON LTV6 LIGHT TOWER (A50854)
2018 WACKER NEUSON...
TEST BID LOT (A50775)
2014 John Deere 635F Grain Platform (A50657)
2014 John Deere...
