Ford 4500?? Backhoe mount pins seem loose. Can I tighten the fit? See pics.
   / Ford 4500?? Backhoe mount pins seem loose. Can I tighten the fit? See pics. #1
777funk
Yanmar/336D
The flow control or maybe control valve itself makes the main boom very jerky. The backhoe feels a little scary to me as a first time operator. I don't like the amount of play in the pins. Is it normal to have this amount of play?I see a bolt for tightening and removal... I'm going to tighten it, but would it be maybe a good idea to replace these? Anything else I can check for safety sake? I'm sure there's plenty of wear since its an old hoe saved from the scrapper, but it all still works. I like old iron, may as well give it the tlc it needs and run it.
To me it looks solid, but I'd like to add and change anything thats gonna make it safer to operate. This one didn't even have a lap belt. Going to add that first.
   / Ford 4500?? Backhoe mount pins seem loose. Can I tighten the fit? See pics. #2
I normally just crank those down when they loosen up.
   / Ford 4500?? Backhoe mount pins seem loose. Can I tighten the fit? See pics. #3
I would look for a manual, but I think like said above there are the clamps that need to be tightened down. Looks like you are starting to have some wear, but probably nothing worth trying to replace.
   / Ford 4500?? Backhoe mount pins seem loose. Can I tighten the fit? See pics. #4
45-55 year old machine worn like that?
Gotta be a design flaw.
   / Ford 4500?? Backhoe mount pins seem loose. Can I tighten the fit? See pics. #5
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2025 JMR Stump Bucket Skid Steer Attachment (A51691)
2025 JMR Stump...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2013 FELLING  SKINNYNECK TA LOWBOY (A53843)
2013 FELLING...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
