Looking to upgrade to a L3240
   / Looking to upgrade to a L3240 #11
I believe it is just the open station that requires a split to add the mid PTO. Cab models came with the internal parts you just have to add the external mid PTO stubshaft.
   / Looking to upgrade to a L3240 #12
Owned a L3130 HST and currently a L4240;great tractors and they turn very sharp.The Grand's have a lot of nice features.
My L3560 is the successor model to the L3240. R4 outside to outside width is 62".
My R4 tires never mark turf. Florida soil is porous sandy loam.
The /40 series of Grand L tractors are the ultimate Grand L models without Tier IV pollution controls installed.
Thanks, that's narrower then I was thinking which is good.
I don't live in Florida, my turf isn't as forgiving to aggressive tires, since I'm doing work for other people I can't really afford to damage their yards.
Even my B at half the weight tore up the grass with R4's.
Yes they do, I was looking at a nice low hr l3130 but I'd rather have all the additional features of the 40 series, even if it does cost me a bit more.
   / Looking to upgrade to a L3240 #15
Kubota L3240 - dimensions
2007 - 2013 L40 Series
Compact Utility tractor
Previous model: Kubota L3130
Series next: Kubota L3540
Kubota L3240 Tires:
2WD Standard tires (ag): Front: 6.00-16. Rear: 12.4-24
4WD Standard tires (ag): Front: 7.2-16. Rear: 12.4-24
2WD Optional tires (ag): Front: 7.5Lx15. Rear: 12.4x24
Lawn/turf front: 27x8.50-15
27-10.50LLx15
29x12.50-15
Lawn/turf rear: 355/80-D20
41-18LLXx16.1
41x18--20
Industrial front: 10x16.5 (4WD)
Industrial rear: 420/70-24 (4WD)
Dimensions:
2WD ROPS Weight: 3153 lbs [1430 kg]
4WD ROPS Weight: 3395 lbs [1539 kg]
4WD Cab Weight: 3748 lbs [1700 kg]
4WD Wheelbase: 71.1 inches [180 cm]
2WD Wheelbase: 71.3 inches [181 cm]
4WD Length: 114.8 inches [291 cm]
2WD Length: 119.3 inches [303 cm]
Width: 59.8 inches [151 cm]
Height: 90.7 inches [230 cm]
Ground clearance: 14 inches [35 cm]
2WD
[120 to 150 cm] 2WD} 45.5 inches [115 cm] {4WD} Front tread: 47.6 to 59.4 inches
Rear tread: 47.2 to 58.3 inches
[119 to 148 cm]
2WD turn radius: 8.5 feet [2.6 m] (with brakes)
4WD turn radius: 8.9 feet [2.7 m] (with brakes)
Page information:
Last update: March 8, 2015
Copyright: Copyright 2016 TractorData LLC
Contact: Peter@TractorData.com
Previous model:Kubota L3130
Series next:Kubota L3540
Kubota L3240 Tires:
2WD Standard tires (ag):Front: 6.00-16. Rear: 12.4-24
4WD Standard tires (ag):Front: 7.2-16. Rear: 12.4-24
2WD Optional tires (ag):Front: 7.5Lx15. Rear: 12.4x24
Lawn/turf front:27x8.50-15
27-10.50LLx15
29x12.50-15
Lawn/turf rear:355/80-D20
41-18LLXx16.1
41x18--20
Industrial front:10x16.5 (4WD)
Industrial rear:420/70-24 (4WD)
Dimensions:
2WD ROPS Weight:3153 lbs [1430 kg]
4WD ROPS Weight:3395 lbs [1539 kg]
4WD Cab Weight:3748 lbs [1700 kg]
4WD Wheelbase:71.1 inches [180 cm]
2WD Wheelbase:71.3 inches [181 cm]
4WD Length:114.8 inches [291 cm]
2WD Length:119.3 inches [303 cm]
Width:59.8 inches [151 cm]
Height:90.7 inches [230 cm]
Ground clearance:14 inches [35 cm]
2WD
[120 to 150 cm] 2WD} 45.5 inches [115 cm] {4WD} Front tread:47.6 to 59.4 inches
Rear tread:47.2 to 58.3 inches
[119 to 148 cm]
2WD turn radius:8.5 feet [2.6 m] (with brakes)
4WD turn radius:8.9 feet [2.7 m] (with brakes)
Page information:
Last update:March 8, 2015
Copyright:Copyright 2016 TractorData LLC
Contact:Peter@TractorData.com
Yup I look at tractor data all the time also. To bad they don't list the actual width of the different tire options. That's what you guys are for!
Went and looked at it today, in good mechanical shape, cosmetically it has a but if fading from being outside/under an open lean too but I think I can clean it up. Needs a new RF tire but they aren't expensive, also hopefully will be picking up a set of turf tires tomorrow.
Have a couple possible glitches I want to look at like the parking brake light not coming on every time and the pto not showing engaged right away every time, not sure if that's normal or not. Could just be a lose connection.
Got home too late to play with it, just unloaded, took the bucket off and parked it. 20201221_195946.jpeg
Kinda regretted testing/playing in the dirt/mud right before loading it for the 300mi trip...........20201221_120142.jpeg
   / Looking to upgrade to a L3240 #19
Got home too late to play with it, just unloaded, took the bucket off and parked it.View attachment 680636
Kinda regretted testing/playing in the dirt/mud right before loading it for the 300mi trip...........View attachment 680635
Congrats on the tractor but your new rig has R4(industrial) tires;changing to turfs will involve a rim change and all four need to be changed(due to tire circumference and the 4 WD system).I assume it's 4WD.
   / Looking to upgrade to a L3240 #20
Have fun. They are a beast. I've moved tons of dirt, rock and concrete with mine along with brush hog and tillage.
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2013 Doyle Dry...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
