I have had a US Yanmar 165D for many years. It's first owner, a municipal government, always left it outdoors in this rainforest next to the Pacific Ocean, but it wasn't a rust bucket when I bought it. I have never left it outside (15 years now), and now that it is 40 years old it doesn't look bad for it's age and 700 hours. It was delivered new with the YBH 656 backhoe and the YFL front-end loader.
It's in need of new hydraulic hoses. It may actually have the originals. Getting ready to change all of them I began with removing the boom hoses on the backhoe. Even though there is no visible corrosion I cannot remove the NPT fitting. A wrench was clearly going to just round off the corners on the 9/16 inch hose fitting. A box-end line wrench wouldn't fit due to clearance with the cylinder. I cut off the hose so I could use a socket. The socket on a breaker-bar easily rounded off the fitting. I drilled a 1/4 inch hole through the fitting so I can have some leverage. So far I have nothing that will fit through the hole and not break off instead of the fitting coming loose. I have applied 3 different chemicals sold for helping, including PB Blaster. This looks like a simple problem, and it is, but I cannot loosen that fitting. I have every reason to expect that every one of the hoses will be like this. Does anyone have any ideas? Thanks.
