Fuel injector “0” ring question
   / Fuel injector “0” ring question #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
Is there anything special about diesel fuel injector “0” rings?. Can’t seem to locate replacements for Bosch injectors but I’ve got a large assortment of Viton “0” rings and I’m sure I can find one that’s very close. I assume the Viton rings should work if I can find a close enough replacement?????
   / Fuel injector “0” ring question #2
A quick Google search pops up lots of results on Amazon eBay injector shop etc. for Bosch fuel injector o-rings - diesel or otherwise.
What do you have and where have you looked so far?
Those o-rings are critical for compression and fuel air mixture. I would think that guess and check at the sizes would be a last resort
Here’s a pic of the injector but I can’t find anything online that references the numbers on the data plate. Haven’t tried to contact Bosch but that’s my next step assuming they have a consumer help line.
   / Fuel injector “0” ring question #4
No not really. I have four different o-ring kits, the only one that is special are the HVAC green o-rings.
   / Fuel injector “0” ring question #5
Not to be stupid or anything, but where exactly is the o-ring that you want to replace? Is it on the low pressure side / high pressure side? Is it in the injection pump itself?
That part number (Deutz 04271701) is a common Deutz injection pump, $380 or so on eBay at the moment...The shim under it is a big deal as that sets the timing, and may need to be changed if you change the pump.
All the best,
Peter
So I should be good to go as long as they fit..?? I’m going to see if Bosch will help me tomorrow. They have a help line but I’ve got low expectations.
All the best,
Peter
I pulled the injector “the part I circled” when I was bleeding the fuel system after sitting for 3 years without running. There’s an “0” ring sealing the injector in the base. The motor runs like a champ once you get it going but it’s losing prime overnight. I haven’t been able to locate the leak but I’ve replaced the fuel filter, all the hoses, clamps and inline fuel between the lift tank and lift pump.
Forgot to add pic of the part I removed.
2016 FREIGHTLINER CASCADIA DAY CAB (A51222)
2016 FREIGHTLINER...
EVERYTHING SOLD AS-IS WHERE IS!! (A50774)
EVERYTHING SOLD...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2012 Lincoln MKX SUV (A50860)
2012 Lincoln MKX...
2016 CATERPILLAR 259D SKID STEER (A50458)
2016 CATERPILLAR...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
