Rockbadchild
A car lift would be nice... if I'd me more extrovert I would have one ....
They burn the spurs off before we get them. Keep them a year. They are grown back by then. But, they're used to me and not so bad.I agree! I think I'd go into their cage armed with at least a 12ga.
Only downside is you won't be able to get at the center of the vehicle, so exhaust work, RWD/AWD driveshaft work, brake/fuel line work, possibly fuel tanks and RWD transmission work are all out.Ok, I think this is going to be the lift I buy for a couple reasons. 1. I want to be able to move it between my garage and my MILs barn. 2. I don't want to put a permanent lift in her barn and I don't have room for a permanent 2 or 4 post lift in my garage. This however is a compromise and I'm staying under $3k.
Anyone have any experience with these?
Yes, those are all things I have no plans of working on. I'm going to be doing brakes, differential fluid, oil changes, tire rotations, Struts (just ordered new struts for one of my 20 year old new to me cars). If I do all of those things to two cars, the lift will have paid for itself already. I have 3 cars and my boys both have two cars. It will be used very much.Only downside is you won't be able to get at the center of the vehicle, so exhaust work, RWD/AWD driveshaft work, brake/fuel line work, possibly fuel tanks and RWD transmission work are all out.
Aaron Z
Considering I used do oil changes off of Ramps with a sheet of cardboard to lay on, it will be a huge improvement. I can sit on a rolling chair and do most of the work I plan to do. That is 4 feet high which is about sitting down hightMaximum Lift Height (in.):
48.00 in.
Is that going to be high enough to do a lot of oil changes?
for me.
That looks great. The Dannmar company appears to have been bought by BendPak and is sold under the name MaxJax. Some improvements have been made by Bend Pak. @YanderMy son just put this in his shop. He knows his stuff and did a lot of research. Mostly for working on his old Bronco and GTO.
