Draft Control on 5145
/ Draft Control on 5145 #1
confederatemule
I have a 5145 Mahindra. I know what draft control was on older tractors. It automatically kept an implement, such as a plow, at the same depth when going over un level ground. Such as a field with terraces across it.
Does a 5145 have that capability? I don't think so cause there is only one control lever.
/ Draft Control on 5145 #2
Draft control is the same on old or new tractors. It allows the implement to raise and lower according to the load on the implement to maintain a constant draft. This reduces slippage of the tractor tires to maintain maximum traction.
If yours has a rocker on the top link as shown in the video, it has draft control and will have the second lever.
This is a picture of where my top link attaches. But there are no external control lever nor linkage.
/ Draft Control on 5145 #4
It shares a hinged toplink connection with other models, but is not hooked to anything. Like you said, no 2nd lever either. Owner's Manual shows PC or position control only for that model.
