JD 5420 Not turning over
Hello all
Basically:
Battery is good.
There's power coming to and from the ignition terminal on the ignition switch. But, no power making it through to the solenoid.
No fuses blown
PTO indicator is off (which to me means the switch is ok, right?)
Also, doesn't seem to be any power making it to the neutral switch, either.
I can't find a wiring diagram for this online. I'm assuming there's a few relays and safety switches that could be the problem, but without a wiring diagram....
Any body know what the issue could be? Before I start manually tracing wires.
Thanks
Jon
Hello all
Basically:
Battery is good.
No fuses blown
Thanks
Jon
