BonBon1981
Thank You all for your input so far.
It's been much appreciated, Sorry it's been so long since my last post. BUT... my husbands hip popped out the socket, Then he had revision surgery on
July 25th. He is feeling much better now.
First Off, I cannot believe how much we have learned so far. We have replaced,
Ordered & Replaced
- Starter
- Solenoid
- Bad PTO switch
- All Fuses, Diodes, & Relays
- fuel shut off solenoid
- Batter load tested
- Replaced the fault light code bulb
(Bought a pack of 10 for $10)
We also replaced the suction tube elbow (pg. 280 of technical manual)
TM 1985 Dec. 2002
What I think we should concentrate on is the fault Light, Which would tell us exactly what is wrong.
Our tractor is the e power reverser model.
BUT the fault code light does not come on at all. According to the manual it should come on automatically, when you turn the key; but unfortunately it does not.
As opposed to the E Hydro, is a little different. OR We could look at something else.
The tractor starts fine, & after 10 seconds it shuts itself off. The bucket & the Rear of the tractor move up & down fine, while It is running.
BUT during the 10 seconds of the engine running it will not move forward, backward or anything.
We tested the break switch & the clutch switches, They were fine.
Also, the transmission is the 4 speed A,B, & C. Which I think they call it a 12 speed (it would be A,B,C & neutral & 4 speeds).
I think fixing the fault light would be a good idea. We aren稚 sure why it does not work. Secondly, could it be when I changed the suction tube hose?
Thank You all so much,
Bonnie & Simon
Ordered & Replaced
- Starter
- Solenoid
- Bad PTO switch
TM 1985 Dec. 2002
Bonnie & Simon
