HD4010
Member
Hi,
I have a problem with my 4100 hydro and was hoping someone on here might be able to help.
For reasons I wont get into I was running with a dead battery that would not take a charge. I jumped it and was running it for about 30 minutes or so that then it died on me like the key was turned off. I put it in neutral and jump started it again but when I put it in gear it died, even though I was on the seat. I started again, got off, lifted the seat and manually pushed the safety switch under the seat and then put it in gear and it immediately died. I restarted and then heard a hissing noise and smoke poured out from under the tractor and it smelled of electrical stuff burning.
I shut off and stepped back, looking for flames and when I didn't see any and the smoke cleared I popped the hood and took off the side panel and could see the end of the fuel shutoff solenoid was melted. I touched it and blistered my finger it was so hot.
Obviously I need a new solenoid but I'm wondering what might have caused this. Is this a symptom of a bigger issue?
Could it be related to running it with the bad battery?
At $180 a pop for a new solenoid I don't want to just replace and fry the new one if there is an underlying problem. How should I go about diagnosing if there are other problems? If it were just a bad solenoid I suspect the first symptom would not have been it dying and then starting again but dying when put in gear...
Any help is greatly appreciated.
Thanks,
HD
Thanks,
HD
