Tractor was running good a few weeks ago. Over the holiday I wired in some LED cube lights for additional visibility. After I wired them up I verified they worked but I didn't start the tractor. The switch has a small light that is always on, so it's always pulling current (though it shouldn't be much). A few days ago I went to start the tractor and it wouldn't crank. The operating lights on the dash were on but faint, so I assumed that my old battery needed to be replaced. After I installed the new battery I turned the key one position and noticed that all of the dash lights were fully lit. I then proceeded to turn it one more position to fire it up, and something 'clicked' and all power was gone. I tested the batter and confirmed it is fully charged. I pulled and tested the (30 amp) key switch fuse and confirmed that was still good and confirmed that there is power getting to it (12 amps getting to the fuse). When I put the fuse back in and turned the key, the operating lights came on again. Then when I tried to turn it over, something 'clicked' and they were off. There is currently no power to the switch.
Any ideas of what to check next? Starter? Solenoid? I heard about a small chip behind the fuse panel that can sometimes to bad? I bought the tractor used and don't know much about it, and am not a mechanic by any stretch of the imagination, but would like to try to diagnose/fix this myself if at all possible. It's 10 degrees here so it's not great weather to be 'tinkering' but I use the tractor to clear the driveway, and with a pregnant wife I need to make sure it's ready to go at all times!
Any thoughts would be appreciated!
