Lieber
Was draining the front axle,center bolt,decided to check the small bolts on each end one came gushing out,the other just dripped real slow as if it was empty,so I opened the top big plug and it came gushing out the top.I ran a wire thinking the bottom plug must be restricted,but nothing?I gave it a shot of air and it all came out the center plug on the axle,never did come out the bottom plug on that side.I decided to drain the axle because the site gauge was reading empty.I dont have a manual,but It seemed to have almost 2'gal in the axle.When you fill the axle thru the top plug,I'm assuming it all eventually goes where it should if on level ground??? This is a dk40 se 2013 with 110 hours. Anybody have any ideas??
