bradthesing
Helping a friend with his Kioti DK35 that will not start. We turn the key on, glow plug light comes on and eventually goes off, then turn key to start(one of the two identical relays under hood on fire wall cycles) but engine does not spin over. It has a new battery. On the starter solenoid we jumped the small solenoid control wire to the heavy positive wire going into the starter solenoid and three tractor starts up. Spins over great with plenty of power. Volt meter showed good voltage. Headlights work, dim slightly when spinning tractor over.
Swapped wires to relays on fire wall, opposite one cycles when key is turned to the start position.
Not sure if the solenoid that cycles when key is turned to start is part of the electric defueling.
The electric defueling actuator linkage is disconnected prior to him ever getting the tractor. Has a mechanic defuel pull linkage to kill tractor.
Are both firewall relays supposed to energize? One energizing allowing fuel the other energizing sending power to engage starter solenoid?
Headed back over to look at the tractor again today. Going to check safety circuits, if any... Has mechanical pto and gear shift transmission.
Any additional direction would greatly be appreciated!
