cjoffutt
Does anyone know which pin is ground and 12v? Trying to wire up a trailer connector to use my 3 point sprayer via the 7 Pin, but none appear to be supplying power. I'm assuming the large pin at 12 o'clock is ground?
Either that or I'm missing a fuse that will let the 7 Pin work. The pig tail on the tractor side goes to some other wire harness right between the rear tires, then to the rops lights and goes under the seat area.
