MinnesotaEric
Super Member
A potential weakness I found in my due diligence web search was an occasional complaint of suspended Ferris mowers to chew up deck belts. This may be due to misinformation as at least one dealer is telling people online that Ferris claims the throttle should be wide open before engaging the PTO. Page 17 of the Ferris IS2100Z Owner's Manual states:
I always turn on my decks at idle or as slow of engine speed as I need to prevent stalling in order to save the electric clutch. Even so, the Ferris IS2100Z (and maybe IS700Z) 52" deck takes a 5V (5/8" solid V-belt) that is 162.4" long (Ferris part number 5103927).
There didn't seem to be an exact aftermarket replacement but the following Kevlar 5V 161" belt should fit on. I'll report if it doesn't.
B158K - B-SECTION KEVLAR (K-PLUS) V-BELT
It is best practice to engage the PTO with the throttle set at the minimum throttle position necessary to engage the deck drive system without stalling the engine.
