runharley52
- Joined
- Mar 18, 2015
- Messages
- 58
- Location
- Iowa
- Tractor
- 1990 Ford 445C; 1989 Ford 4610, Westendorf TA-25 FEL
New to me tractor got delivered today. 1990 with 2800 hrs or so. I have a 1989 4610SU 2wd so they’re about the same under the hood but with some key differences.
I liked the lift capacity and 4wd. I have a lot of logs to move and dirt work to do and I felt like I was beating the front end up on the 4610. It also has top and tilt, foam filled tires, and the shuttle shift/reverse options sounded much better for snow blowing vs the gear shift on the 4610.
We will see which one I like to keep long term. I don’t do much real ag work besides bush hogging and some dirt work.
I will order the manuals but I have some questions.
The torque converter lock button on the f/r shifter. Do you use that when you’re at speed? Like a cruise control?
There is a switch on the right side of the steering wheel that I assume is a preheater maybe for cold weather? How does that work?
Should there be float for this loader? I see electronics on the controls but I couldn’t quickly figure out float.
On the right hand side on the motor there is a plug that is taped over. Block heater maybe?
Probably more to come but thanks for the help in advance!
Pics below
Pics below
