Chris Sargent
We have owned this tractor since new about 2005. about 700 hours now and it has been a headache since day 1. My current problem is when the ignition key is turned, it is hit or miss if the ignition controller will turn on. (dash lights, fuel pump, etc. I have to on/off, on/off, on the key or bump the engine to get it to come on. Then once the tractor starts, it will sometimes die while in service. I replaced the ignition switch and tried to trace the wires to ensure there are no loose ends. I have read on some posts that the safety switches tend to draw down the voltage and produce this type of behavior. It was posted that a Relay can resolve this issue. Would anyone be kind enough to elaborate on this.. I am aware of relay function, installation etc... But I need specifics on circuit intervention and part/s..
Thanks in advance!
Chrisullinghair:
Thanks in advance!
Chrisullinghair:
