1/4 hose for toplink
   / 1/4 hose for toplink #11
The restrictors for my 3 point backhoe were a small hole washer dropped in before the hose was screwed on.
Very clever, Xfaxman. :thumbsup:
Any drawback to doing this, that anyone can think of? Might the washer affect the ability of the male fitting to seat fully? Any risk of deformation under the hydraulic pressure? Nickle plated washers or stainless steel? If I ever need flow restrictors, this solution seems like it would come in handy. But it's so simple it worries me!
   / 1/4 hose for toplink #12
The problem when using any type of flow restrictors on a high usage hydraulic cylinder is over heating the oil. So you need to be sure that when using restrictors, you have a large oil capacity or an oil cooler.
   / 1/4 hose for toplink #13
The main advantage of larger hoses on your front or rear remotes is when you are going to run hydraulic motors with the hoses. If you are just opening and closing hydraulic cylinders on a CUT or SCUT, you will be fine with 1/4"
Instead of washers you can just plumb in a flow control valve. They aren't that expensive and you can dial it in exactly what you want. Running one little cylinder a few times isn't going to heat up the oil to worry about it. If you were running a motor constantly, yea, time to worry.
   / 1/4 hose for toplink #15
I would not call any back hoe cylinder other than the out riggers, only being used a few times. Yes typically T&T cylinders and implement cylinders are not a problem, but any unit that is getting a constant use for a period of time can become a problem if things are not properly allowed for.;)
Yes, my post was pertaining to the top link, hence why I said little cylinder with little movement.
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2019 Ford Explorer AWD SUV (A55853)
2019 Ford Explorer...
2015 Ford F-250 Liberator 3200 1.5 Ton Crane Service Truck (A55852)
2015 Ford F-250...
Portable Restroom (A54865)
Portable Restroom...
UNVERFERTH 210 LOT NUMBER 16 (A53084)
UNVERFERTH 210 LOT...
