120v submersible pump for a 2" well casing
   / 120v submersible pump for a 2" well casing #22
There you go! There are lots of brands of deep well or convertible jet pumps that will work on 115V. You will need a packer assemble to put on the bottom of the pipe and a 2" casing adapter for the pump to fit the pipe. The Goulds J5 gives good pressure from deep wells and will do about 7.5 GPM.
   / 120v submersible pump for a 2" well casing #23
   / 120v submersible pump for a 2" well casing #24
   / 120v submersible pump for a 2" well casing #25
Yup.....Gould's convertible jet pump.
And only Gould's,...... skip the cheap junk!
   / 120v submersible pump for a 2" well casing #26
<sigh>
$2000 for a hand pump, that's crazy! I called a local well company today, they sell a deep well jet pump and all the needed parts for ~$1100. Thanks for all the info!
   / 120v submersible pump for a 2" well casing #28
$1100 for a jet-pump setup? That sounds ridiculously high. Read up on what all is required and do it yourself. Not a difficult task.
yeah, and that wasn't even installed, way too high.
   / 120v submersible pump for a 2" well casing #30
A Gould/s J5 convertible jet pump can be bought for under $500.
Other parts/fittings are necessary, but total would still be well under $1,000.
2019 Troy-Bilt Pony 42X 42in Riding Mower (A55853)
2019 Troy-Bilt...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
2021 CAT 304E2 (A53317)
2021 CAT 304E2...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
Polaris ATV (A50324)
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
