1510 complete service and inspection
   / 1510 complete service and inspection #111
little bit done tonight after putting the kids to bed.
Putting gear oil in the front diff and out drives. They had gear oil in them when I drained them, so I went back with the same. It took exactly four quarts.
Got the gauge cluster bracket installed.
Next is some painting...
Sorry for the late reply Asymair95 but I've been away from TBN for quite awhile doing a remodel on my daughter's house. Great job and great thread!
I went thru the fluid change on my tractors and it was pretty important to use GL4 gear oil instead of GL5 on the front due to Ford's use of copper / bronze in the gear housings. You might want to research this a little. Maybe the 1510 is different?
Thanks SLD, will look into that.
Just wanted to update this thread and close it out. $2500 later, the 1510 is running like new again. The repair shop pulled the pump and timing cover to check pump timing. They found a bent governor linkage and tried to bend it back, but ended up having to replace it. The injection pump also needed rebuild. Once it was back together they used a dyno to make all the adjustments on the pump.
I’m glad it is fixed, but upset I let myself get taken advantage of like that. This was one of those impulse buys I should have walked away from. I’m now 10k into this tractor and would never be able to recover it if I had to sell for some reason. It was an expensive lesson to learn, buyer beware.
   / 1510 complete service and inspection #113
Hey man, glad you finally got it figured out. Sucks to have to spend that much, but you should have a decent tractor that will only need fuel, oil and filters for a long time. Post up a few pics of it working!
   / 1510 complete service and inspection #114
Yes, you are into it for a lot. But you know what you have. Use it and enjoy it. Glad it's worked out.
Kubota LA525 Front Loader Tractor Arm Attachment (A55851)
Kubota LA525 Front...
LaneShark LS3 (A56469)
2003 Big Tex 10PI...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
UNUSED FUTURE XJ5T 36" HYD THUMB CLAMP (A57193)
UNUSED FUTURE XJ5T...
