18' trailer price check
   / 18' trailer price check #11
......................................I'd hook up your loader (if equipped) and rear attachments and measure the length.
I don't know what a new 4T Hudson goes for but I'd find out then ask what the seller wants. In my area sellers would ask about 2500-3K for that. If you can get it for less I'd say that's a buy. There is a 18' 5T on Ebay the seller is asking $4500 or B/O for so a good price an 06 4T is tough to call.
George2615 sounds right to me. Hudson is a respected trailer brand in my area. I would expect to see around a $3000 asking price on this trailer along the side of the road. If he'd sell it for around $2000 you would be getting a great deal (if everything fits on it). Try loading your machine on and towing before you negotiate. At 2k I would not even mind loaning it back to him on occasion.
   / 18' trailer price check #12
In my area, I would value the trailer somewhere between $1500 and $2000. The Hudson trailer is a good trailer. I do however feel you will not be satisfied with the 18' length. I recently purchased a 22' long 12K rated trailer. The stand up ramps are very handy, but as someone else mentioned they will limit the length you can load due to not allowing overhang in the rear, unless you want to remove them temporarily. I looked for quite a while at used trailers, but wound up buying new. You may have no issues with the arrangement, but some times it is better to buy out right and not be tied to sharing equipment. I have seen this "strain" relationships. I never mind loaning to friends, but always worry when borrowing if they had plans to use the equipment at the same time I wanted it.
   / 18' trailer price check #13
I do not care of it has 5 miles and the tires look brand new its going to need new ones. Trailer tires take a beating compared to car and truck tires. 60% the cost of new max but if its not long enough do not wast your time. Remember, you need room to balance it and chain it down. Those flop up ramps also severly limit what you can haul.
Chris.
   / 18' trailer price check #14
Hey guys,
A friend of mine is selling his 18' trailer and I'm thinking about buying it. It's not really what I want as I want a 20' or 22' trailer, however, I'm wondering if I should buy it rather than buy a brand new trailer.
I need to measure my tractor and maybe even try loading it onto the trailer to see if it fits, but assuming it does, what do you think a good price would be for the trailer?
The guy selling it is a good friend of mine and he'll probably still borrow it in the future whenever he needs it, so we are looking for a fair price for the two of us.
it was built in 2006 according to the sticker, it hasn't had much use, in fact it's been sitting for 2 years but I don't believe the tires are dry rotted. Neither of us know if the brakes work in it and it does have obvious surface rust. Structurally it seems fine, just don't know about brakes and axles?
What are your thoughts for a fair price on a used trailer like this? Or should I just skip it and buy a brand new trailer I want? i'll be using it 1 to 2 times per month to go 120 miles, mostly highway. The weight capacity should work for me.
to do a new version of this trailer would be near $3,000. half price for a unit with wear and unknown brakes would be fair. Give it a test load and if it works for you, i would snag it.
   / 18' trailer price check #15
I don't think you can buy that trailer new for $3K; you can offer $1500 but don't be disappointed if you are turned down. $2K would be a fair price.
   / 18' trailer price check #16
I sell a brand new 18' flatbed with 9,990lb GVWR and pullout ramps for $2,999. Every day, out the door. FYI... :). Throw on the bobcat ramps and you are at $3249. do it in a tilt for $2945.
here is an 18' 10k tilt for reference off of my facebook page..
Pretty close to three grand no matter how you look at it.
It looks like right around $3800 to $4000 new for the same trailer from the Hudson dealer in my area. It's strange how prices vary so much by region.
I've been keeping my eyes peeled on CL for a longer trailer more like what I want, but it doesn't seem like there are too many out there, tons of 16 footers around but not many that are bigger.
I'm gonna bring the trailer over my house and try the tractor on it and see how it fits. If it doesn't fit then it's a moot point and I won't be buying it but I think it will work.
I do have a brush hog for the tractor and I know that won't all fit on the trailer. I will most likely be leaving the brush hog up in NH and only trailering the tractor back and forth, so it may not be tooo much inconvenience but it sure will be some.
Ideally I really want a bigger trailer. The situation is I can either buy this trailer, and buy a box blade and top and tilt for my tractor, OR i can go buy a new trailer, and no box blade and TnT for the tractor......Hence the reason I'm trying to make this do for now.
   / 18' trailer price check #18
That Hull quick tilt looks a little scary to me. All the weight looks to be on the rear trailer axle and the frame hitch when it is tilited. 9900 lbs. is alot of vertical load to be splitting between one trailer axle and my truck's frame hitch.
The tilts that keep both axles on the ground look alot more appealing to me.
   / 18' trailer price check #19
if it's a 10k trailer then you should figure that probably the carrying capacity is about 8k, with the trailer being the other 2k, give or take. as you start to load the trailer only part of the load is on the axle. the rest is still on the ground. by the time you have the front of the load clearing the first axle, the back of the load is still bearing on the end of the trailer, which is still bearing on the ground. i bet it would be hard to actually drive something on the trailer and have over 5k on any one axle. if the trailer and axles are rated for 10k then loading something that is 8k won't bother it at all.
   / 18' trailer price check #20
My concern was more about getting 3 or 4000lbs. of downforce on my hitch. My tractors run 6-7000 lbs with an attachment on the three point. If you get 6-7000 lbs of tractor up on a long lever between the back trailer axle and the hitch, its going to be pushing down pretty hard on the back of my truck.
MULCHER (A58214)
MULCHER (A58214)
2016 Chevrolet Tahoe SUV (A54815)
2016 Chevrolet...
2394 (A58376)
2394 (A58376)
2012 FORD F-450 FLATBED (INOPERABLE ) (A58214)
2012 FORD F-450...
2860 (A56857)
2860 (A56857)
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
