jpilk99
- Joined
- Feb 19, 2011
- Messages
- 319
- Location
- Bolton, MA
- Tractor
- 1983 Ford 1700, 4WD, 770 Loader, Woods backhoe, Woods brush hog,etc.
Seemingly overnight, my awesome 1700:
Had a harder time than normal starting
Actually seemed to 'catch' and run okay, but, just wouldn't get it's idle or rpms up
It surged for a minute or two and then ultimately ran ...okay. I've got the brush hog on but not slogging through anything crazy or wet.
Then, after sitting all night on a slight grade - so it was kinda tipping to the left a bit - same thing in terms of a little hard start, but, once it was running, just surging - slowly - and never evening out at the normal great idel/rpm (once throttle arm opened up).
I thought I might be low on fuel, and especially tipping to the side, so I dumped in what diesel I had (barely a half a gallon), and no difference. Went and got a 5 gal tank filled, came and dumped it in and almost the same thing.
I put it in gear and drove to level ground and the idle came up a bit ...but it just seems to be running at 1/2 to 2/3 power. I thought of my other lawn tractors when only running on one cylinder - but that was always because of spark missing (either bad plug or ignition coil). Obviously not the case on diesel.
I took a pass in the field with brush hog going and it did okay, but, just no rpms/no power. And it was running strong AF 2 or 3 days ago.
Did I somehow get air in the fuel lines, once fuel level was low and machine tipped to one side?
I wondered if I put bad/old fuel in it, but, after dumping in the better part of 5 gallons of fresh diesel, I can't believe that would be the issue.
Any ideas?
Thank you,
Jay
Any ideas?
Thank you,
Jay
